Only Fuel soelnoid turning on :(
Old Apr 7, 2006 | 01:42 PM
02Vortech's Avatar
Default Only Fuel soelnoid turning on :(
oaky so my nitrous has been going strong for about 3 weeks and now the nitrous noid wont turn on- on the fuel noid- (I know this is much better than the nitrous noid instead of fuel noid)- check all the connection for the power and its getting 12volts- HOW DO I CHECK A GROUND WITH A VOLTAGE METER?- because i need to make sure its getting grounded other wise its fubar'd
Old Apr 7, 2006 | 04:36 PM
NXJeremy's Avatar
I would suggest taking the two wires from the nitrous solenoid and connecting the directly to the positive and negative posts on a battery (a 12v cordless drill battery works well for testing solenoids). If the solenoid does not activate, then it is definately fubar'd (the coil is more than likely fried). On the other hand, if the solenoid does activate, then you will know that it is something in the wiring of either the ground or the hot side.
Old Apr 7, 2006 | 11:01 PM
02Vortech's Avatar
its fine- redid the nitrous ground and it was fine- thanks for the help- i love this thing- and yall made it happen- more vids comming tommorow night - Blazer vs. WRX, 350z!!!! (100shot)
Old Apr 10, 2006 | 10:01 AM
NXJeremy's Avatar
Good to hear. Looking forward to seeing the video.
