ZEX TPS sensor connection on Corvette...help!
Old Apr 7, 2006 | 06:09 PM
wavrdr's Avatar
Default ZEX TPS sensor connection on Corvette...help!
Hey guys, I'm in the final stages of finishing my Zex install on my ZO6(drive by wire)and have run into a jam on the TPS wire connection. Which one is it?
I am running an LS2 TB and according to the C6 guys, the green wire is the one to use, but that one does not work.....
I am now thinking that I'll have to bypass the LS2 harness and tap into the original tb wiring harness, just unable to find the correct wire...
Any help is appreciated.
Alan
Old Dec 9, 2006 | 12:48 AM
camaronx's Avatar
I talked to a zex tech guy bout my 05 gto m6 who said that one wire was rising signal and other is falling signal so he said either one should work. I have had mine on the purple wire and the nmu greeen light comes on so thats cool. I've had the kit since april and haven't ran it on n20 yet--and i did hear of someone else who had problems (05GTO)with the purple and went green. I gotta get some a/f ratios b-4 i do anything much--pretty much got the rear mods needed for 125 shot from zex system.
Old Dec 9, 2006 | 01:11 PM
Robert56's Avatar
Check the wiring sticky?
Robert
Old Dec 9, 2006 | 02:17 PM
wavrdr's Avatar
Thanks guys..I took care of this a long while ago...Still haven't used the spray though...
