250 shot
Old Apr 12, 2006 | 09:20 PM
Cbrakllr's Avatar
Default 250 shot
Ok i have a quick question, if im looking to run a 250 shot ( most likely TNT) should I do two stages with two bottles and all that? Or should I go with one kit with a progressive controller? I think one kit would be better but im no expert on N2O.
Old Apr 13, 2006 | 12:43 AM
CAT3's Avatar
Restricted User
Looks like your running stock bottom? if so, definately progessive as it will keep the torque under control, as 383LQ4SS' experiments have proven, yet get the power to the ground.
Old Apr 13, 2006 | 09:43 AM
GDM Z28's Avatar
single stage.....invest in a really good TC and a nice set of tires....something big....talk to 1999transamws6 or something like that (joe) he has a stock bottom end (205 afr heads and a baby cam) and he made 428 on motor and 667 on nitrous with a single stage 250 shot dry. he also went 10.2 @ 135 using a foot break (1.6 60ft)
Old Apr 13, 2006 | 11:08 AM
NXJeremy's Avatar
With a stock bottom end you could possibly save a little money by going with the single stage w/ progressive controller. The use the saved money on other things like converter, tires, suspension, or accessories for the nitrous system.
Old Apr 13, 2006 | 04:17 PM
sprydncamd ta's Avatar
check out harris speed works i run their progressive controller and my buddy runs a two stage that they setup for them
Old Apr 14, 2006 | 11:21 AM
Cliff's Avatar
Originally Posted by GDM Z28
single stage.....250 dry (1.6 60ft)
Wow..............that is crazy. Must have a really good fuel delivery system.
