Injector question ?
Old Apr 20, 2006 | 08:59 PM
SPRAYED 01's Avatar
Default Injector question ?
Do the fuel injector play any part in a wet kit? Or does the fuel solenoid completly take over when spraying?
Old Apr 21, 2006 | 12:13 AM
nostyta's Avatar
No your injectors do not play any part on a wet kit, the injectors are still working but the extra fuel needed to componsate for the nitrous is injected by way of the fuel soleniod with the wet kits, you'll just need to check your a/f ratio to make sure you have it jetted right ( not running to lean or rich ).
I'm no nitrous expert, so maybe somebody will correct me if I'm wrong.
Old Apr 21, 2006 | 01:50 AM
CAT3's Avatar
Restricted User
Nope nostya you got it basically correct. Fuel injectors merely supply the engines naturally aspirated fueling. One thing you want to watch for is fuel starvation, wet kits tapped off the rail tend to suck the fuel from the injectors, without having a rail mount regulator, end result watch cyl #5 and 7. GL
Charlie
Old Apr 21, 2006 | 12:27 PM
SPRAYED 01's Avatar
Where and how much is a fuel regulator and do i need an entire new rail?
