Filters
Old Apr 24, 2006 | 11:58 PM
code4's Avatar
Default Filters
Is there a need to run a filter before the fuel solenoid? It would seem that the fuel from the fuel rail is already filtered?
2nd question, is it true that you just clean the nitrous filter with compressed air & re-use?
Old Apr 25, 2006 | 12:46 AM
charlie c5's Avatar
Your correct, the fuel is already being filtered. So no, you don't really need another filter. As for the N20 filter, you can very easily clean them with compressed air.
Old Apr 25, 2006 | 12:57 AM
CAT3's Avatar
Restricted User
I like this, someone else wanting filtered power! Not needed if using fuel from the rail, Dedicated yes needs filter. unscrew caps and blow out in reverse flow for nitrous filter, and can be checked for flow by simply blowing thru them. Not too expensive to swap them each year or xxx amount of bottles.
Old Apr 25, 2006 | 04:54 PM
code4's Avatar
Thanks for the replies, heading back to the shop
