finally sprayed the z
Old Apr 29, 2006 | 08:09 PM
2002z28's Avatar
Default finally sprayed the z
well it was a long time coming, but i sprayed the z last night. what a rush. the car is running way rich since i put the stock maf on. 12.4-1 NA and 11.5-1 on nitous.
special thanks to nitro dave for supplying all the parts and ricky from trick perforance. my window switch got fried and ricky replaced it.
im spraying a 100 shot, but i can see that being bumped to a 150 shot in no time.
justin
Old Apr 29, 2006 | 08:13 PM
Reject's Avatar
did you run a tune on that shot or what? (i'm still learning about the nitrous side of things)
Old Apr 29, 2006 | 08:27 PM
HolyShiznit's Avatar
Was this on drag radials or honest street tires?
Good times regardless.
Old Apr 30, 2006 | 09:28 AM
2002z28's Avatar
i had a tune done when i had the slp85mm maf, then i had to put the stocker back on so i could use the nx maf kit. its getting less air, so it makes sense that the car is running richer.
yup that 12.9 was on stock gsc tires. my 60ft time was around 2.01. look at my trap speed, if i could hook off the line i could be running 12.7's.
