FJO Green light not coming on?
Old Apr 30, 2006 | 06:08 PM
2scoot's Avatar
Default FJO Green light not coming on?
I'm trying to set up the FJO contoller and can not get the green light to come on while adjusting the WOT on the unit. I turned off the 1st gear lockout feature and still nothing.
Any ideas?
Old Apr 30, 2006 | 11:34 PM
trembles's Avatar
turn key on engine off , hold throttle wot, turn screw until light comes on then back off 1 turn
Old May 1, 2006 | 02:44 AM
pewter 01 SS's Avatar
try doing it both ways.. sometimes (if you bought it from someone else) you might be going the wrong way.. or in my case the wire that i spliced of the computer wasnt getting a good connection
Old May 1, 2006 | 08:06 AM
2scoot's Avatar
I bought it new and went the 25 turns for the falllng voltage per the instructions, then key on, engine off and turned the screw still nothing. I'm curious if I need to change somthing in the FJO configuration or if it even matters. Anyway I'm calling FJO and see what they have to say. Its has to be something minor.
Old May 1, 2006 | 09:38 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Ok why did you do the falling voltage? If on that wire the TPS must be checked to falling. Give me a call and I would glad to help you out.
888-463-2781
Ricky
Old May 1, 2006 | 06:09 PM
2scoot's Avatar
I got er done today. Called FJO aand they gave me the info I was looking for. Seems I was using the wrong TPS wire. IF you have a 04 ZO6 you want the Blue one and set the FJO accordingly.
Also I was leaning toward the falling voltage due to a post that had been submitted that basically said that they had recorded spikes in the voltage which could cause faulty signals back to the FJO unit.
