Trick two stage wiring question
Old May 3, 2006 | 10:01 AM
Beer99C5's Avatar
Default Trick two stage wiring question
I have a Dry switch (Stage One) and a Wet switch (Stage Two), where on the relay does the "Load" for in cab master switch (On/Off) for each stage go?
Old May 3, 2006 | 10:44 AM
860 Performance's Avatar
use your switches to break the yellow and orange wires
Or run your arming switches to #86 on the relay.
Old May 3, 2006 | 12:11 PM
BadAssFast's Avatar
Why would you do that?
--Macon
Old May 3, 2006 | 12:18 PM
Macon, new screen name? I didn't reconize you.
So you can run 1 stage or both if you choose, from in the car by flipping switches.
Vinny
--Macon
Old May 3, 2006 | 01:07 PM
BadAssFast's Avatar
Vinny
Sort of "incognegra" lol. Okay - I see control issue...cool. From this years runs, I too, see the importance of multiple stages. I like the idea of multiple progressive stages best. Thanks.
Old May 3, 2006 | 01:11 PM
Beer99C5's Avatar
Damn...LOL may leave the system arm/window switch/TPS/ stuff for you Vinny...
The gromment is not pretty either
Got the remote bottle opener running with the NX switch...Very Nice...
Got the Heater cooking...
Got the remote N2O Pressure gauge running (Blue wires are da ground not the Black )...
Got the Main Feed Line to the Double Noid stack...
Anyways...thats a good start...
Old May 3, 2006 | 01:30 PM
Spenser309's Avatar
do it from 86, that way you can just ground the wire somewhere in the cabin it would use less wire, and if need be you could have a master for both along with a master for each.
