cam?
Old May 9, 2006 | 07:58 PM
Spladamie's Avatar
Default cam?
Well I asked about this in the internal section and figured I would ask here as well. Im thinkin about a custom comp grind that would keep my power band relatively low and work well on spray and off. The specs I have in mind are 226/232 .588/.595 110+2. The basic response in the internal section was that the lsa was too low. But with these specs the cam would only have 9* of overlap so I dont see any reason for a higher lsa? I was thinkin this cam would probably peek around 6200 and shift points would be at 6500 which works good for me as well since I dont really wanna spin my stock bottom end any higher. Thoughts?
Old May 9, 2006 | 08:04 PM
227Hawk's Avatar
Open the LSA up, that 110 center isn't going to make power till the top end. Try looking in the 112 or 114 LSA you'l be happier. And the 114 will probably be best.
Hawk
