Need info on nitrous
Old May 11, 2006 | 09:50 AM
BIG_MIKE2005's Avatar
Default Need info on nitrous
Ok guys, I was against running nitrous & wanted to stay N/A. Now I'm considering it. I am going to be a H/C car N/A. I need to know how nitrous friendly my cam will be. Here are the specs.
Custom Grind Comp Cam
232/238 .576/.584 112*4
I am only pondering using a 75-100 dry shot.
Old May 11, 2006 | 02:09 PM
ttt...
Old May 11, 2006 | 02:58 PM
CAT3's Avatar
Restricted User
Your cam wont maximize the nitrous, but it wont spit it all out the cylinder during bleed-off either. Whats that mean, you and both run the same jets, in theory I should make slightly more power than you, by virtue of retaining the cylinder pressure and other cam timing events. The difference may be small as just a couple hp, or larger, but your cam will work. Have you read the nitrous FAQ's section and Colonels Nitrous Tech Files? Lots of good info in there.
