Here's my (stealthy) install.
Old May 17, 2006 | 09:39 AM
  #41
BADSZ28's Avatar
Originally Posted by keliente
My car is setup for a cam too. The only thing I do when I want to spray is hook up the bottle and reflash a different tune.
What kind of gears do you have? I have sprayed with both 4.10s and 3.90's. As far as plugs, since I have only used the n20 twice in the eight months it's been installed, I left the regular TR55's in place. For a tune I just suck a couple degrees of timing out. I'm sure there is a lot 'more' left in my setup, but like I said before it's just to fool around with.
I was using the window switch from 4100-6000 last week...feeling frisky I dropped down to a 3,000 pill (it was the next lowest I had). I launched and came pretty damn close to nailing the wall Gave me a good scare!!
Thanks for the reply. I am running a 4.56 right now and only have 26" tires. As it sits I know I will need 28" tires. I should have gone 4.10s so I could stay 26" but so many cars run 4.56s with bigger cams that I figured it was best. But then I ran into a great deal on a dry kit that I may take. Problem is I am already at 100%+ duty on my injectors and just bought the 9" with these gears. I do not want to run any taller than a 28" tire either. I am pretty broke too. So if I get this I would probably need 4.10s and injectors at the least. Then two sets of tires, 26" for N/A and 28" for spray. So I am looking at a total investment of like $800-$1000 or so.
Old May 17, 2006 | 10:07 AM
  #42
keliente's Avatar
^^^ Oh I'm sorry I forgot to mention that I have 42# injectors. Not because of the n20 though. When I dynoed with the cam, I was at 114% duty cycle! Now with bigger injectors there's more room to grow, they handle the cam fine with room to spare for the n20.
Old May 17, 2006 | 10:08 AM
  #43
Ben R's Avatar
Bow Chicka Wow Wow.
Old May 17, 2006 | 10:48 AM
  #44
WS6HUMMER's Avatar
Pretty slick!
Old May 17, 2006 | 11:02 AM
  #45
BADSZ28's Avatar
I have to see what Bosch has for injectors. Hard to find specs for these.
Old May 17, 2006 | 11:23 AM
  #46
Lightning's Avatar
BEAUTIFUL install, thats exactly how id like to set my kit up!
Old May 17, 2006 | 12:08 PM
  #47
silverado01's Avatar
Very nice
Old May 17, 2006 | 02:36 PM
  #48
keliente's Avatar
Thanks.
When I first started thinking about nitrous I looked at a lot of different setups, but didn't find one done how I wanted it to be, so I just made it up as I went along.
Old May 17, 2006 | 05:37 PM
  #49
BURN'EM's Avatar
What's wrong with behind the seat? It's no different than people mounting it between the rear seats or on the trunk deck thinga ma jig.
Nothing really it does need to be bolted down though.
Old May 17, 2006 | 05:46 PM
  #50
krazy4's Avatar
that could help
Old May 17, 2006 | 06:42 PM
  #51
lovin_myZ's Avatar
ok i might be dumb or so but that is a dry kit right. and what shot are you running. Im thinking about doing the same thing to mine but not sure if i want to go wet or dry ... i think wet is the best way, but i could be wrong what do you think.. that is a clean install.
Old May 17, 2006 | 08:07 PM
  #52
keliente's Avatar
Yeah its dry. I have used a 75 shot and a 100 shot.
Old May 18, 2006 | 08:45 PM
  #53
Reject's Avatar
nice install very stealthy
Old May 18, 2006 | 09:11 PM
  #54
Ben R's Avatar
How many PM's have you gotten from guys asking if you want to go on a date with them?
Old May 19, 2006 | 07:19 AM
  #55
keliente's Avatar
None.
Installing nitrous isn't rocket science, plenty of women could do it if they just tried. I've done more things that I consider more difficult that installing nitrous (like setting up rear ends or even doing a cam). N20 is just soldering (big deal) and getting creative with hiding things
Old May 19, 2006 | 02:15 PM
  #56
BadAssFast's Avatar
None.
Old May 19, 2006 | 11:33 PM
  #57
cantdrv65's Avatar
Wink
None.
Thats because all of us single guys know you have a boyfriend.....If Mr right ever turns into Mr wrong your PM box is going to overflow.
Old May 20, 2006 | 06:27 PM
  #58
2000Hawk's Avatar
That hidden set-up you have is one of the best i have seen, good job.
-Joel
Old May 30, 2006 | 11:03 AM
  #59
98 SNAKE EATER's Avatar
Any pix of the nozzle placement?
Rick
Aztek T/A WS7 & 70 RAM AIR IV T/A
Moderator @ LS2, FAST LS1, FUELSLUT,
The F-Body Hideout, LS1Turd & ChopperForums
Old Jun 7, 2006 | 09:53 PM
  #60
keliente's Avatar
I just read this post now - and finished taking off the n20 about two hours ago because I am selling the car Otherwise I'd have snapped a pic for you.
Just imagine opening the airbox and seeing the filter, and in the middle of the filter about 5" apart the nozzles came through. It was flush across the top of the filter.
