TNT micro switch
Old May 17, 2006 | 06:39 PM
BBBBadSS's Avatar
Default TNT micro switch
Are all micro switches universal? I have the TNT kit with the ring, its the micro switch and bracket that came with that kit. Will any micro switch fit this TNT bracket? One of the terminals on it broke off.
Old May 17, 2006 | 07:58 PM
Matt@HSW's Avatar
They pretty much are universal. I believe TNT does sell them if you want to replace it with there’s, but any should work.
Matt
Old May 19, 2006 | 12:57 AM
LoWeLL216's Avatar
The micro switch doesn't connect to the bracket anyway unless they've changed it. But yes, they're all pretty much the same.
Old May 19, 2006 | 09:39 AM
David@TNT's Avatar
Yes and no, it is a standard switch but they are roller tip which makes them harder to find.. Call us and we will get ya lined out, thanks David@TNT
Old May 19, 2006 | 09:40 AM
David@TNT's Avatar
Btw yes they do mount to the sol bracket now, David@TNT
Old May 19, 2006 | 04:56 PM
LoWeLL216's Avatar
I stand corrected...
Old May 20, 2006 | 04:07 PM
NaughtyIROC's Avatar
You know you can get a pre-made custom bracket w/switch for your setup if you were interested in that. :-)
