Bored at Work / Part Two
Stand alone fuel system for the 2 nitrous kits .
3 gallon fuel cell , walbro 255 and aeromotive regulator in a return fuel system using 6an forward and 4an return lines .
Im going to make a new cover out of aluminum that will be wrapped in
the carpet material and lock it down with quick locks .
Thought ide share
After i wired both of the fuel pumps up ,the nitrous pump wasnt working and Bigmike noticed one of the relays had the prongs set 90 degrees in it casing so i pulled it apart and wired it up acordlingly , so Not all relays are the same even tho they make look the same .
Its good to have a mikiepoo hanging around ,, haha
