NOS Bottle Heater question - Wiring
Old May 21, 2006 | 03:09 PM
MetallicaMatt's Avatar
Default NOS Bottle Heater question - Wiring
hey guys,
will the NOS bottle heater, with the pressure sensor, will it still heat up without the bottle connected? I've got everything wired up, w/o the bottle on (not filled) and no heat???
I am NOT using the supplied 3 prong switch. It basically just has the LED on it, so I'm using a 2 prong micro switch.
I believe the one wire to the prong should be switched 12V source and the other connects to the Red wire on the relay
does this sound right?
heres the wiring diagram
https://www.holley.com/data/Products.../199R10309.pdf
thanks guys
Old May 21, 2006 | 05:38 PM
Robert56's Avatar
It should get hot even without bottle. Check your wiring again.
Robert
Old May 21, 2006 | 05:57 PM
i double checked everything
i think my problem is with the switch i'm using
instead of using the 3 prong switch w/ led that they provided
i'm using a 2 prong micro swich. from the relay, a red wire runs to the one prong. What should the other prong go to? Ground? 12v source? I've tried both?
Old May 21, 2006 | 07:39 PM
Robert56's Avatar
If the red wire is going to the relay as in your pic, then the other prong needs to be switched 12v. The 3rd prong is a ground for the sw light.
Robert
Old May 21, 2006 | 08:55 PM
thats what i figured.
i'll give it a try on friday, i'm back at school. so look for this to pop back up by the end of the week lol
thanks Robert!
