Wondering about #7.
NXRicky
the last time i sprayed my car (new 370) with the 175 NX wet single nozzle, 25* timing, TR6's @ .050" gap, 11.2:1 c/r....i melted #6 plug, all the rest of them looked fine. yes i know this was a kinda wild/extreme setup but it was a last min. grudge match.
can you give me any thoughts on this?
Ricky, if you take the above as a consideration, wouldn't riching that clylinder help with cooling?
Possibly we have a lean condition and a heat/detonation problem and thus the #7 issues.
Robert
NXRicky
Robert
after that i will probably put a cross over tube on the rear, like the one on the front with the ls6 intake and see if that changes anything too.
Robert
no prob man, i was just wandering if he though i could have had the nozzle turned slightly to one side to make it do this.
Robert
yea, i did the plugs @ .050" for the break in on the motor. i sprayed a 100 shot on it a few times and it ran great. then on a spur of the moment grudge match i slapped the 175's in her and it ran good till about 1/2 way through 3rd
but i still beat/drug a 383lt1 on a 200 shot
NXRicky
175hp 25timing, 50gap and 11.2.
Now why it attacked #6
several reason could have been. If the heads were ported or casting the cylinder had a hot spot. once detenation starts it is self feeding. meaning the only way to stop it is detune via shutdown the hp demands.
TR6 plugs as good as they are are still a street plug 150 or less hp.
Bad rings got a little oil in the hole.
So many possiblities, see every engine is different. Every one of them. They are just like people no two are same, even if you use the same parts they are still different.
The leason is since you know you had a problem with #6, do not repeat or else #6 will go again.
Less timing knock it down. gap the plugs closer to 35 and use good gas.
By the way what gas where you using.?
Ricky
Ricky
thanks, its going for a full dyno tune on the 3rd (200+ shot
) and all the stuff will be right then.i was running the good ole pump 93 at that time
the heads are patriot stg. III's so they *should be exactly the same, rings are filed at .030" gap for a LOT of n2o also
its pretty much a pure n2o motor and thats what i'm gonna do to it
Kidney stones are no joke
Ricky, good reading as always...I wish everyone would realize what works for me, may not for you, etc...too many times I see the "this is the way it has to be" BS.
So its not sustained like running around for an hour and then spraying hard.
Hmmmm... Very interesting. I've seen as much as a 300 degree difference between the front two cylinders and the rear two cylinders on big CID engines using a (front of Intake mounted T/B)... I have some projects coming on line in a month or so and if I can figure out how to post a EGT data logger graph from a chassis Dyno run I'll do it...
Till then.
Thanks either way. Charlie
