Nitrous Plug Size?
Old Jun 3, 2006 | 02:06 PM
DAPSUPRSLO's Avatar
Default Nitrous Plug Size?
I've got an sb2 intake which was previously used with a direct port nitrous set up. I need to plug these holes as i'm staying n/a for the time being. My question is what size (thread, diameter, pitch) is a nitrous direct port nozzle usually. It looks about a 5/16" to me, but the thread is not coarse or fine, is there any other sizes? Thanks.
Old Jun 3, 2006 | 02:12 PM
TJ's Avatar
TJ
should be 1/8 NPT
Old Jun 3, 2006 | 04:06 PM
DAPSUPRSLO's Avatar
Originally Posted by TJ
should be 1/8 NPT
That small huh, maybe these holes weren't for nitrous then? I'll try to get in touch with the guy I got this stuff from. thanks.
Old Jun 3, 2006 | 04:07 PM
TJ's Avatar
TJ
1/8 pipe doesnt measure 1/8. its more along the 5/16 you are reffering too on an actual outside measurement.
good luck.
Old Jun 3, 2006 | 04:14 PM
DAPSUPRSLO's Avatar
good luck.
Oh, ok. Well then a 1/8 pipe plug may work then you think? Thanks for the help!
