test
Old Jun 7, 2006 | 11:18 PM
flash12t's Avatar
Default test
how do u test the kit with a window switch . .?? i wanna make sure they open when i go full thottle. .
Old Jun 8, 2006 | 11:01 AM
thunderstruck's Avatar
im no expert, but i just disconnected the fuel & nitrous lines from the nozzle & then put the ends in a container, then had the car revved up to the bottom setting on the window switch, then manually pushed the wot switch.
Old Jun 8, 2006 | 12:33 PM
flash12t's Avatar
sounds easy enough ill give it a try thanks. .
Old Jun 8, 2006 | 02:15 PM
terry s's Avatar
You can disconnect the 12v wire to the solenoids and run a wire from the wire feeding the solenoids to a 12v light bulb and ground the other wire from the light bulb. Put the light bulb in the car with you or tape it to the windshield.
This way the power to the solenoids is disconnected. You can take the car out and see when the light comes on the solenoids would have activated and when the light goes off the solenoids would not be activated. This works for testing the complete system to see if the solenoids will work when you think they should be working.
Old Jun 8, 2006 | 02:40 PM
very creative!!!
