Diagram Request TB and Timing Tuner
Old Jun 10, 2006 | 11:07 PM
AgFormula02's Avatar
Default Diagram Request TB and Timing Tuner
Ayone have a diagram for this set up?
I looked and did not find one. I am using the basic TB and Nitrrous diagram, but the TT states:
With the timing tuner you will now trigger through a 12V switched source.
Remove chassis ground for NOS relay and attach gray wire for the timing tuner"
OK, I am good so far. I assume the ground will be provided via the timing tuner.
Here is where it gets wacky, specially with the TB set up:
"Your 12v switched wire will now be powered through your arming and WOT switch."
