Purge Help
Old Jun 12, 2006 | 07:56 PM
LSTBRED's Avatar
Default Purge Help
I dont know what this means, if anything,I checked the bottle after purging and it got cold, the purge line is getting cold (it's only 10" long), high pressure blow, everything seems fine, but no "cloud"? why is that? I really dont care about show, I just want to know if this is normal.
Old Jun 12, 2006 | 11:39 PM
TUMBLRws6's Avatar
does anything come out at all???
whats the temp outside??? that makes a huge difference in the "size of purge plume" If its really humid then you should be able to see SOMETHING (if its working properly) the more humid and hot the better, when i do it when its raining...its like a friggin fog machine...
~also...if your holding down the button for too long...you might be stopping up the line with "ice" I know when i hold it down for just a few seconds it freezes up and frost starts to develope on the line and the end of the nozzle.
hope this helps a little...
Old Jun 13, 2006 | 12:16 AM
LSTBRED's Avatar
It does a cold high pressure blow, it was about 85* today when I worked on it. I did hold it down for an extended period today trying to figure sh*t out. Thanks for your help.
