Which window swich / controller?
The dual window switch is a window switch, tps and any gear lock out. Its digital and uses push buttons. $129
The FJO is just like above but has a progressive unit that can be RPM ramped or time based. It requires a Labtop to program. $206
The NOS is just like the progressive above but does not have a RPM ramp and uses a hand held controller to program. $223
If the NOS does not have rpm ramp how does it ramp?
Plan is 100-150 shot maybe 175 progessive if possible?
Nitro Daves Plate system
Window switch or progressive controller unit FJO or NOS
860 Fully Auto Heated Bottle Bracket will it work with a 15# bottle?
Fuel pressure safety switch
N20 Pressure gauge
Should I get a spare 10# bottle or one 15#?
Anything else you guys suggest?
TIA
