Double checking wiring
Old Jun 23, 2006 | 12:08 AM
BigDB's Avatar
Default Double checking wiring
ok its a NX kit, I have been studying the wiring charts on here and I just want to double check the wiring. I get switched 12 volt and ground to toggle, from ACC I go to my WOT switch, then to my red wire on my relay. My MSD window switch also receives 12 volt, ground and tack signal and connects to the white wire on my relay. Green from relay to noids and black on relay to battery. IS this correct or do I wire the WOT switch and the window switch on the ACC from toggle to relay? I take it white from relay is negative?? This is the diagram im pulling this from http://i73.imagethrust.com/images/1R...d-msd-win.html I also need to wire a heater and a purge, I have a second relay for that. Thanks alot
Old Jun 24, 2006 | 08:45 AM
spson04's Avatar
humm, i see you frusration, it is not perfectly clear whether the white wire completes the ground path or power side of the system. you can check easy enough with a test light. One thing for sure it is the msd window switch and fuel saftey switch both must be made to allow the relay to energize the solinoids. sorry cant be of any more assistance
