150 shot ?
Old Jun 28, 2006 | 05:07 PM
Mach1killerls1's Avatar
Default 150 shot ?
went to a local dyno and had my car run with the wideband on a 125 shot dry. a/f ended up being a little fat at a 11.7 on the gas and a 12.73 off. i'm tempted to kick it up to a 150 shot but no sure if its a wise idea any suggestions?
Old Jun 28, 2006 | 06:21 PM
slow trap's Avatar
did you get a look at your injector duty cycle ?
Old Jun 28, 2006 | 07:39 PM
i didn't get to check the duty cycle out but with the 125 shot it only put 113 to the tire. also i have a 98 with the 28.6 # injectors. car on the gas only put down 435 rwhp.
Old Jun 29, 2006 | 06:35 AM
brad8266's Avatar
Not bad man. The injector duty cycle will tell you if you are able to spray more. You need that first.
