First time spraying, have a problem now
Anyone have any ideas about what may have happened? Car ran fine driving home and ran an 11.50 on that one run.
I would just keep an eye on your oil and coolant level. Stick a temp probe on their and verify if the gauge is correct.
But id check the gaskets just to make sure..
was there any smoke coming out the exhaust(more then normal)?
And check around the heads and make sure its not leaking.
If a head gasket is gone does the fluid go into the oil?
Or does it just leak down from the head and down the side of the block?
Could it be the radiator cap allowing it to drain into the overflow?
Not really sure what to think now.
