fuel pressure problem
Old Jul 10, 2006 | 06:54 PM
runningta's Avatar
Default fuel pressure problem
well here is the problem Im running a dual pump setup to my kit. before the 2nd fuel pump went in I was at 58psi so I put a inline pump on so that I can run a bigger shot safly. I was having a problem with the car bogging down when I sprayed it checked a few things and found out I now have a 100psi+ in the fuel line. sooo what should I do here changs the fuel jets down a few or try and regulate the fuel system.
