O-ring for Nitrous outlet plate system.
Old Jul 13, 2006 | 12:18 AM
Dune-LS1's Avatar
Default O-ring for Nitrous outlet plate system.
I need an O-ring for a T/B nitrous plate... <(The O-ring that goes between the plate and the T/B) Does anyone carry those besides Dave? His shop is closed for vacation and I like to get one right away.
I assume an O-ring goes there... Some kind of seal does.
Thanks
Old Jul 13, 2006 | 12:41 AM
Beer99C5's Avatar
It uses the factory TB gasket, so the Chevy dealer should have em.
Old Jul 13, 2006 | 03:11 AM
Dune-LS1's Avatar
I have that one... I need the O-ring or whatever for the other side...
Old Jul 13, 2006 | 03:16 AM
Dune-LS1's Avatar
The gasket/O-ring that goes here... In front of the plate and behind the T/B. The factory O-ring is too small/thin to seal between them... There's gotta be something else.
Old Jul 13, 2006 | 03:45 AM
Beer99C5's Avatar
If I remember right, the origional gasket between the TB and the Manifold, stayed in the manifold, the plate and the new gasket as pictured then had the TB put on it and it was torqued to like 17 ft /pounds or so (not much).
Sealed and works good for me.
Now I was Drinking some ice cold Pete's Wicked Ale and some Sam Adams Lager during the install...but I am pretty sure thats what I did for gaskets on that (single stage LS1 Plate).
