What size wire with TNT system?
Old Jul 18, 2006 | 12:27 PM
blind527's Avatar
Default What size wire with TNT system?
So I have to pick up some more wire as I bought the kit used, and I need to use some more wire...What size wire came with the system, or should I get? 18 gauge? I will be getting Nitro Dave's window switch that has the built in TPS wire so I don't have to mount the WOT switch, just use that. I also have a purge kit, and a bottle heater. Each one of those units will have their own relay. Does anyone know how I should wire the purge kit?
Old Jul 19, 2006 | 01:53 PM
Nitro Dave's Nitrous Outlet's Avatar
For the main hot from the battery feeding relays use 12 gauge. For the system use 16 gauge.
Dave
Old Jul 20, 2006 | 01:48 AM
blind527's Avatar
So from the battery to the relay, use a 12 gauge, and everything else, including grounds, use a 16 gauge? Thanks man.
Old Jul 20, 2006 | 11:24 AM
David@TNT's Avatar
We run 14 gauge wire to hookup the system.. Thanks David@TNT
Old Jul 20, 2006 | 12:06 PM
Yes. That is what we use..
You can use a heavier wire like suggested from David. It will not matter.
Dave
