Dynotune window switch programming ?
Old Jul 22, 2006 | 01:42 PM
oange ss's Avatar
Default Dynotune window switch programming ?
Programmed per the instructions for TPS activation, on 3000 rpm, off 6200 rpm with 1 channel lock out....with the system on, the dispaly reads "O-L-O"...which indicates TPS signal off, 1 channel locked out, 2 channel lock out off....i programmed the TPS activation, so shouldnt it read "1-L-O" ? ...thanx
Old Jul 23, 2006 | 05:18 PM
oange ss's Avatar
anybody ?
Old Jul 23, 2006 | 06:20 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
The first digit will only change when you are at the reconized or programmed into the unit. Just like your L will go away and change to a 1 when you pass the lock out and hit the window.
Ricky
Old Jul 23, 2006 | 06:34 PM
oange ss's Avatar
cool, thanx man
