Speed density and nitrous?
Old Jul 25, 2006 | 10:08 PM
Cliff's Avatar
Default Speed density and nitrous?
Is nitrous compatible with speed density tunes?
Old Jul 26, 2006 | 12:05 PM
srsnow's Avatar
That is not true you may still be able to run a dry kit. Not all dry kits get the fuel through the MAF. Depending on the car and type of fuel system there are sevral ways of adding fuel on a dry system
Old Jul 26, 2006 | 01:53 PM
MrDude_1's Avatar
ive personally only seen two styles of dry kit:
1. sprays the MAF, and the computer "sees" the nitrous with the MAF and adds fuel.
2. the fuel pressure is modified when spraying..... thru various methods.
but the regulator is in the tank on LS1 fbodies, and in the fuel filter on LS1 vettes... making #2 unworkable by normal methods...
so right now, if you're running a SD tune, you need to spray a wet shot...
Old Jul 26, 2006 | 03:05 PM
srsnow's Avatar
There are sevral ways to add the fuel. Some kits used the coolant temp sensor. There was an old NOS kit for the L98's that used a flip chip. And depending on the engine managment system that can also be used to get extra fuel.
So while you may be limited on an LS1 with regard to dry systems if you have a SD tune. To say that all SD setups must be wet is not an accurate statment and could lead to confusion.
Old Jul 26, 2006 | 05:38 PM
MrDude_1's Avatar
if anyone is stupid enough to confuse my SD comment with a speed density system on a motor other then a LS1 running the stock ECM, they deserve to blow their motor up. LOL
im not going to post up the obvious limitations to every statement i make on LS1 tech.
so rather then try to "broaden our horizons" by telling us all about unrelated motors, how about you tell us how to run a dry shot without the MAF on a LS1....
btw, you wont get nearly enough fuel enrichment by just "fooling" the coolent temp sensor on a LS1...
Old Jul 26, 2006 | 05:56 PM
Boostaholic's Avatar
How about this then.
Can you give me a GOOD reason why to use a dry kit on a SD setup?
Old Jul 26, 2006 | 06:14 PM
Black02SS's Avatar
If you run EFILive, they offer a custom N20 OS that has fueling as well as timing adjustments for both N/A and N20. You can use it with a MAF or without.
Old Jul 27, 2006 | 10:46 AM
white2001s10's Avatar
https://ls1tech.com/forums/nitrous-oxide/508006-my-old-c5-numbers-support-theory.html
and
https://ls1tech.com/forums/nitrous-oxide/485211-anyone-play-around-dry-sd-tuning-yet.html
Old Jul 27, 2006 | 11:53 AM
srsnow's Avatar
No because then this post would spiral into a dry vs wet pissing contest and that wasn't the goal of my post. My intent was to make sure there wasn't confusion regarding speed density and what type of kits were compatiable with it.
Old Jul 27, 2006 | 04:42 PM
Cliff's Avatar
I guess I should have added a little more information. I have Nitrous Dave's "money maker" system which is a wet system. I understand the MAF will be obsolete but was not sure a proper tune could be done with nitrous. Thanks
Old Jul 27, 2006 | 04:49 PM
Black02SS's Avatar
Yup. You can do whatever you like as the fueling is controled primarily by the fuel solenoid/jet, not the PCM.
Old Sep 24, 2006 | 08:01 PM
ujslost2's Avatar
Would the pot method with the cts work with a 2 bar OS from hptuners? Would the table(ect vs fuel adder) also add the fuel to the boost enrichment table?
Old Sep 25, 2006 | 10:30 AM
yes
coolant correction works with any fueling method.
Old Sep 25, 2006 | 03:42 PM
charlie c5's Avatar
You'll get tuned for the nitrouus, they will just pull somme timinng..
