Still Surging (Guru's inside Please)
Old Jul 29, 2006 | 12:14 AM
Robert56's Avatar
When's the last time you changed your fuel filter? If it's dropping to 52ish that you see, maybe a delivery problem that is only seen under heaviest load/demand, like when spraying above a certain rpm. A return and regulator at the rails will stop your fuel press drop. My thoughts are if ignition related you will see the issue at wot while pulling a nice hill when not spraying (get the rpms up), try it.
Robert
Old Jul 29, 2006 | 11:48 AM
IMPULSE.ACTIONS's Avatar
Robert
Should I be looking for knock or what on this hill? I have not seen any problems running w/o nitrous on hard pulls and 1/4 times are the same as they were before the surging issue.
Old Jul 29, 2006 | 01:11 PM
Robert56's Avatar
Sure, look for KR. With what you say above, no surging on highest demand n/a, then ignition may be out of the pic? With that said, it still could be ignition with the added demand of the n2o, but less likely. I think this also points to a fuel/n2o supply issue. What about the main fuel supply filter, seen this before, and/or a weak pump? It is real hard to do diagnostics on the internet, and I would look for a good tuner/dyno guy and find the issue. Good luck and keep us updated.
Robert
Old Jul 29, 2006 | 02:44 PM
calongo_SS's Avatar
Try this, run leads from the solenoids to a hand held volt meter in the car. Have a buddy ride along with you and see if you are getting a constant 12 V to the noids. I had a similar problem and I could see the solenoids not getting a steady 12 V.
Old Jul 29, 2006 | 05:32 PM
Did everything else seem to test ok before doing this? I don't know if a volt meter would read fast enough if that was causing the surging though. But right now I'm pretty much at a loss and will try anything to get it going before the 18th.
Old Jul 29, 2006 | 05:50 PM
calongo_SS's Avatar
My problem was a bad window switch. It would hit soft and surge up top. I could see it start at 6 v, and then go up ~13v and start cycleing between 6 & 13 v. Once I took the window switch off it held a constant 13 v, and hit like a ****.
It's worth a shot.
Did you buy the kit new or used? If it's used I bet NX will flow test your feed line and the other peices to tell you if there's something in one of the lines.
Have you opened up the bottle to see if the siphon tube is facing the way you think it is/make sure there is no junk in the bottle?
Old Jul 29, 2006 | 11:15 PM
red90cobra's Avatar
knock is knock how many degrees of timing did it pull for it?
Old Jul 30, 2006 | 12:34 PM
When the surging was going on it would show about 1.5-2 knock and maybe pull 1-1,5 degrees of timing.
Old Jul 30, 2006 | 12:39 PM
It's worth a shot.
I tried running w/o the window switch already and it still surges, but I'll try it again w/ the volt meter.
Used, but it was all only about 3 weeks old, on a car that I know was in beyond mint condition and all worked fine for the first couple months.
This I have not done yet. I can try it, but I didn't have this problem using the same bottles when it was first installed and still get a good plume when testing w/ the line off or using the purge..
Old Jul 30, 2006 | 02:16 PM
chris.shea's Avatar
-tested w/ only feed line (no pressure sensor, filter, etc.)?
this is the nitrous side right?
Fuel pressure is never below 52ish.
Anyone have any suggestions or thoughts on what I could be experiencing or over-looking?
have you checked your Fuel pressure safety switch? your fuel pressure may be "safe" but if the switch is set to 56psi it will cut nitrous till pressure is gained back to "it's safe setting" it will surge cause the pump builds the pressure right back once the nitrous is cut and then gets taxed hard and cuts the nitrous off cycling itself.
Old Jul 31, 2006 | 07:04 AM
correct..
I'm not running a FPSS since I have a FP gauge in the dash.
Old Jul 31, 2006 | 10:48 AM
  #32
94vette's Avatar
okay my thoughts:
run the Basic kit ...confirm throttle switch is on at wot
-keep the system as is and run race fuel.. this will determine if you had knock and was causing the surge.
-if still surges get a wide band and go on the road and test to see if it's too rich. or lean spike
-if still surges i will let know how I test the noids.
Old Jul 31, 2006 | 12:17 PM
  #33
chris.shea's Avatar
Robert
ima hafta agree i always look for the simple things that can be overlooked. everyone else has mentioned everything else possible.
Old Jul 31, 2006 | 08:07 PM
  #34
BNKBRKR's Avatar
I don't know if this will help or not, but mine was doing the same exact thing when I got it (I think it is the reason I got the car as cheap as I did)! I checked everything and tried running race fuel, bigger pump, replaced the fp dampening device on the fuel rail, different pills in the window switch, bypassed the fpss, EVERYTHING!!!! I was thinking about ordering a new kit and I started looking to see how the kit was wired up, and I noticed it was different from how i wired up kits in the past...the previous owner wired the relay to control the power side of the noids and basically the relay was getting hot at higher rpms because you had been pulling it for a while and opening the circuit taking power away from the noids. So I would say check to make sure it is wired properly and see if it feels like the kit is actually shutting off or just not pulling as hard as it should. I think hooking a volt-meter to the noids would be a good idea to. Like I said, I don't know if it will help or not but that fixed my surging problem.
Old Jul 31, 2006 | 08:21 PM
  #35
Robert56's Avatar
Running lean from inadequate fuel system? You haven't answered the question on the fuel filter? and/or weak pump?
Robert
Old Jul 31, 2006 | 08:56 PM
  #36
400rwhp's Avatar
I had the same thing on 02 t/a.My problem was the fuel solinod piston.I went from 75 to 100 thats when the problem started.If you would like to talk give me a call 252-431-5904.Bryan
