TNT website?
Old Aug 1, 2006 | 09:22 PM
1320_PERFORMANCE's Avatar
Default TNT website?
Anybody know the website for TNT? tried texasnitroustechnology.com...doesnt work for me...
having problems w/ my tnt noids...
I rewired my tnt f1 kit w/ my digital window sw....I set the ws rpm on @ 0 rpm to try and spray if it works, the n20 noid would spray/click once and then main fuse to n20 realy would blow, replace it 4 times and still blew, I thought I had a short on the WOT circuit, but all was good....so what I did was eliminate the n20 noid from the circuit and tried spraying again, fuse did not blow and fuel noids was clicking so I think the n20 noids is shorted...
Purchased this kit on July of 2005 but never got around on using it till now, noids been sitting on my car since 2005 so that might of did it, from all the engine bay washing and what not...how long is the warranty on noids? if theres no warranty then Ill just purchase new TNT fuel and n20 noids...
Old Aug 1, 2006 | 09:34 PM
Hangman's Avatar
I know this isn't what you were asking but, if the car isn't going to see alot of track time ditch the window switch if you have a wet kit, or at least get one with pills. I've had nothing but problems with mine, its a MSD digital, when I was at N.L.P. in Orlando Mike had a stack of 3 of them he was returning, they cut on and off randomly under load. As far as the other try googling it
Old Aug 2, 2006 | 12:20 AM
chris.shea's Avatar
you say your noid clicks(working) and when you eliminated your noid from the circuit it wouldnt pop the fuse. hows your ground?
if all else fails i can always bring my stuff(noids, plate, jets, noid2jet lines and my windowswitch) btw is buck still 11.7@120 or did he better that?
Old Aug 2, 2006 | 12:38 AM
JoeyAnderson's Avatar
http://www.nitrous-power.com
You can also PM David@TNT on this forum.
Old Aug 2, 2006 | 02:59 AM
I eliminated the fuel noid first and fuse still blew, so I eliminated the n20 noid and fuse did not blow, I reconnected the fuel noid and it was ok, clicking/working...got good ground contact...Ill just buy a new set of fuel/n20 noids to be on the safe side...Buck hasnt raced since that e/t his gonna be picking up the same tire size as me so will see in 3 weeks how he does....
Joey, website comes up but all I see is red x's..thanks
Any body got there phone #?
Hangman MSD w/s is working fine, thanks
Old Aug 2, 2006 | 10:45 AM
David@TNT's Avatar
Im not sure about the website so I will check it out, but if you need call us @ (903-839-5498) thanks David@TNT..
