QUICK Zex question!!!
Old Aug 3, 2006 | 08:27 AM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
Default QUICK Zex question!!!
I am about to buy a used base zex dry kit off of a friend of mine who had it hooked up on his f150. It was basically the bottle, WOT switch and the purple solenoid box.....My question is, will i be able to hook up a window switch and purge etc too this kit later on...As far as i know now, it would switch on as soon as it is WOT and i dont want it spraying under 3k.
Old Aug 3, 2006 | 10:54 PM
SSDoubleK's Avatar
Wink
Yes, do not buy the MSD Digital Window Switch, I had it did not like it,It's been sent out for repair and have not had it returned yet to me and its been over two weeks, not very happy with MSD at the moment. I'm running the Zex Traction Control Window Switch and so far so good, very compact and works great. Purge no problem, I 'm also running a ZEX purge with not problems.
Old Aug 4, 2006 | 11:30 AM
Nitro Dave's Nitrous Outlet's Avatar
Yes you can still run a purge and a window switch. You will have to wire the window switch in with a relay.
Dave
