Dry nitrous experts
Old set up was 346 cam only with bolt ons and a 125 dry shot that worked great untill rod bearing failure,
New set up is 383 small bore, 5.3 heads and a big cam, 90mm fast everything else the same as before,
The dry kit is as it was when it worked fine on the 346 but now on the 383 it is too lean its like the maf doesnt see the n20, afr was 12.5 untill the dry came on it spiked 14.8 then falls to 13.9 but doesnt drop any lower
If anyone has any input please chim in
The VE tables are exactly what they where with the old 346 tune this doesnt sound right to me but anyway looking at the PE table the cammanded afr is13.7 at 4800 rmp and 14.06 at 6000 and above shouldnt the PE been set closer to 12.8-13.1 the the VE tables adjusted to get the desired AFR? Would this affect the fueling for the dry shot? On the dry shot AFR was very close to the cammanded AFR of 13.7 at that rmp
