MSD WS tach wire hook up
Old Aug 6, 2006 | 11:57 PM
BigDB's Avatar
Default MSD WS tach wire hook up
im looking for what wire to tap into for my ws tach signal. The car originaly had the same kit on it with the same window switch. I looked at my computer harness and the white wire in the harness has been cut and tapped. Where do I need to tap into at?
Old Aug 7, 2006 | 11:53 PM
SSDoubleK's Avatar
Wink
White wire 10 for our 98's, try taping just below the cowl, that's what I did. Still working just fine.
Old Aug 8, 2006 | 01:00 AM
BigDB's Avatar
what is white wire 10? I see a white wire in the harness to the computer, is that the one u are refering to. If need be i can take a pic of the wire that is tapped up
Old Aug 8, 2006 | 10:11 AM
thunderstruck's Avatar
if you look on the top of the ecm, there are small numbers stamped in it. look for #10
