spark plugs and timing
Old Aug 7, 2006 | 12:29 PM
vipershark11's Avatar
Default spark plugs and timing
ok in my 89 305 tbi with a 125 wet shot i want to know if i can run with the ac delco rapid fires i just put in or if i have to change them to something else? what should the gap be?
also should i retard the timing? i heard 4 degress but that sounds like a lot.
Old Aug 7, 2006 | 12:56 PM
white2001s10's Avatar
You'll want to go colder on the plugs.
Nippon Densor T20's
or Motocraft 32C's
should work okay.
Gap them between .028" and .035"
The timing depends on where you are right now.
It also depends on how hot you're running the engine when you spray.
The idea is to keep out of spark knock and detonation when you're spraying.
Old Aug 7, 2006 | 01:37 PM
are any of those autolite plugs i got easy/cheap access to those? also ill prob spray when my cars running maybe 200 or 180 degrees so how much timing would that be?
Old Aug 7, 2006 | 02:49 PM
Autolite AR12 should work well for the bottle.
They are taper-seat. If you have flat-seat heads for some reason then go with AR51.
Again it depends on where exactly you are right now, and such things as if you're getting spark knock at WOT now.
If you're going to be running near 200*F and you don't know exactly where you are right now, then go ahead and pull the 4 degrees.
Old Aug 7, 2006 | 03:08 PM
thanks i just dont want to risk anything to blow my motor but right now i havent gotten my kit yet ive got it all coming within the next week i just want to get all parts together so im prepared to put it in and be safe with tuning it with timing and what not.
