To prove my point nitrous does help make things worst during a fire
1st. I did not read what was in the can. ( a little gasonline ?)
2nd. from what I can see you are injecting nitrous into the button of this can that has something burning it. correct?
IF you spray air pressure into this type of test you will get this huge flame throwing effect. Just like blowing on hot coals they glow more, not becuase of nitrous becuase you are moving more air to the flame. You are spreading the burning media around, hence a larger flame.
Nitrous has to release its oxygen to help the fire. MOST fires I have seen are where you have a back fire, and we all know what happen there, and then the nitrous can spread the fuel around.
Now at XXX? heat the oxygen will get released, So in a CAR fire that got burnt to the ground the nitrous play in this would be the spreading of the burning material until the temp got XXX hot, then there will be more oxygen to make a better fire.
A true test would be to put the fire in a sealed enclosure, then add nitrous to the enclosure and see if the fire stays lit.
Back fires are nasty little problems that can happen and do happen from time to time, just like crossing the road, a piano could fall on you.
Ricky
In fact if you read the label on nitrous bottles it will usually say that it will support combustion.
From the label on an NX bottle.
"WARNING: HIGH PRESSURE OXIDIZING LIQUID AND GAS. VIGOROUSLY ACCELERATES COMBUSTION"
The fact is that introducing nitrous to a fire will cause the fire to burn hotter and faster. Which is why you need to retard timing with nitrous, it increases the burn rate. The other thing is that in an oxygen rich environment a lot of things that normally would not be considered a fuel can become a source of fuel for a fire. If you took a coal or piece of wood that was just smoldering because it had burn all the fuel it could in its current environment and poured liquid nitrous on it it would cause it burn again until it had used all of the oxygen that the nitrous introduced.
Ricky
Ricky,
The can has a hole in the bout 2 inches up from the bottom. I filled the bottom bout a 1" with kerosene. I used some hardline I had laying around bended it 90 degrees so that the nitrous is pointing straight up. So it's not blowing on the flame. It's just adding more air to the unburnt fuel making it bigger. The line is bout 2 inches taller than the top of the fuel. I lit it the fuel let it burn for a bit then hit the nitrous. It's definitly doing something. It's bringing in a different colored flame. kinda like greenish/blue colored.
Ricky
You cant compare an engine cylinder to an open engine bay. EVERY bit of nitrous that is ingested into a cylinder WILL be broken down and the oxygen will be utilized in the combustion of the fuel. The nitrous cracks quickly under compression, is swirled around and is spread out evenly.
An open engine bay full of fuel is completely different. If you have an open -4 line hooked to an open 15 lb bottle of nitrous and its spraying through the middle of a flame ( not near the base where the fuel is) it likely will have minimal effect on the fire. As a matter of fact I would bet that the majority of the nitrous will exit the opposite side of the flame. Iam sure a small amount on the fringes would reach the temp needed to crack the bond and release the usable 02 molecules.
Now compare that to an open -4 line pointed at the base of a superhot engine with puddles of fuel everywhere anf possibly fuel coninueing to be pumped in the engine compartement. The effect of that nitrous IMO would be two fold.
One would be the agitation of the fuel, making it a finer spray. Obviosuly a fine mist of fuel will burn alot quicker than a pool of fuel.
Second would be the actual heating of the n20 until the 02 molecule would be released. Again...under most curcumstance, in an open engine bay I seriously doubt that 100% of the nitrous would reach that temp. So what % would actually become usable o2 to suport the flame? Who knows...depends on the EXACT situation. And since N20 only contains a little bit more 02 than regular air...to make the fire worse...it would have to be a high % 02 released from n20 to exceed what would normally be in the air.
IOW...the amount of heat an engine fire may impart on a high velocity jet of n20 shooting through a flame likley would not come close enough to extract 100% of the o2 from the n20.
I personally think the agitation of fuel and the "stoking" of the fuel/fire from the high velocity n20 plays as big or likely bigger part to the fire than the increase 02 content.
Thats why the MSDS sheets say fire hazard is negligable. Its somewhat of a trade off.
1. Race gas burns slower than 87 octane pump gas! Fact! Dont believe me, go fill your empty tank up with C16 and make some NA runs, compare to 92 octane (or wtf ever octane you run in your mom's car) and see how much slower your times are.
2. Nitrous Oxide, although an oxidizer MUST meet the 572*F before the oxygen is released from the Nitrogen molecules. It simply will NOT add to a fire blowing across it, as Al stated, it would most likely, under the recommended pressure, push right across the flame front with little if any broken down and consumed.
3. Liquid Nitrous Oxide DOES NOT Enter your combustion chamber. When used in an internal combustion engine, the juice goes from a liquid to a gas! GAS man, vaporific type substance, not a solid, not a liquid. It also goes thru phase changes along its path to the chamber, everytime it encounters a difference in line I.D., across the solenoid orifice, and once released from the jet (or open line) it is allowed to expand and thus changes from liquid to GAS. Even the reference above is flawed about holding an open line into water bottle...sure you may get liquid nitrous settling...ONCE THE BOTTLE REACHES LOW ENOUGH TEMPERATURE TO SUPPORT REALIGNMENT OF PHASING BACK TO LIQUID. BUT IT DOES NOT HAPPEN IN AN INTERNAL COMBUSTION ENGINE!
4. Now, in the story of the car with a backfire, and open nitrous line, the nitrous being exiting the line is a GAS, and unless the engine fire temp reaches over 570* it WILL NOT CONTRIBUTE TO THE INTENSITY OF THE FIRE BY ADDING OXYGEN (i.e. being and oxidizer)...however, having a 900pound per square inch breeze if you will, blowing across an open fuel line with fuel escaping, will contribute by virtue of the fanning effect.
In the slim chance the fanning, from the release of such a pressurized GAS across the race fuel reached over 570*F, then and ONLY then could the open nitrous line contribute in a OXIDIZING manner.
Just think about the experiments and if you're really wanting to PROVE anything of the such, reinact the mishap to the best of your ability.
i agree on what your saying. it depends on the situation I guess.
Now I really need to learn how to type those long explanations, like 383 and CAT.
Ricky
Ricky
Like maybe a BBQ grill with the lid on, the bottom vent closed and the top vent as the nitrrous feed line. Now if you could just find one with a window so you can see what happens...lol.
I can't help but wonder 'why' that DVD was not incuded with my kit...
However, check out this nasty backfire from piedmont last year, http://video.ls1tech.com/video/21b31...17014ae5ea.htm . Check out the intense flame that erupts from under the scoop. I can't help but wonder if this was a situation where the nitrous did act as an oxidizer.
