Nitrous missing in second-third gear
But for a wideband 02 and a tune would be close to another $1k, that would bring up my total to almost $3k, I don't think so. Granted I could use the o2 in the future (just like the fuel pump), but that's a long ways away.
We always suggest knowing if the car is running rich or lean. The guys that just put it on and hope its right are the guys that always tear something up. Then they blame it on nitrous.
When using power adders no matter what type air fuel is critiacl. So is timming, and fuel supply.
I think we need to back up a minute and figure out why your car is pinging..
Its either running lean from not enouigh fuel pump or needs bigger fuel jets. Or it has to much timming. The spark plug gap could be a problem but shoudl not cause pinging.
I just reread your origianal post. It says the fuel pressure drops to the low 50s.
How low exactly and how does it recover?
Dave
Dave
First thing we need to determain is why the huge pressure drop.
How is the bottle mounted in the car?
If you hold the bottle in your hands and crack open the valve does it stay a huge white solid cloud?
Dave
That was the second run.
Here is the first run.It pulled better in third except for a little detonation at the end. http://s170.photobucket.com/albums/u...=stivsz281.flv
Good luck!
