Will my fuel system handle 150?
Old Aug 8, 2006 | 10:32 PM
CharlieSS's Avatar
Default Will my fuel system handle 150?
I am installing a nitrous system at a reputable shop. The guy told me that my car cant handle a 200 shot. Can it handle a 150 if I have stock injectors and just a holley 255 fuel pump??
Old Aug 8, 2006 | 10:39 PM
1fastws6_02's Avatar
Default i say yes
mine is doing just fine with the 200 tnt and 255 walboro pump and stock injectors (i ran the stock injectors for 2 yrs)i just upgraded to the 30 lbs svo inj.
Old Aug 8, 2006 | 11:11 PM
Z2K_MrJ's Avatar
Board Certified Idiot
Yes If it is a Wet System It Can. Also itYour Car is Close to Stock In Mods You Dont even Need the PUMP. But its allways better to be Safe then Sry
Old Aug 9, 2006 | 12:46 AM
blind527's Avatar
Yeah, I know people that run a 150 wet no problem on a stock fuel pump. It's always to be safe than sorry.
Old Aug 9, 2006 | 04:55 AM
SPLATT's Avatar
agreed. not to sound like a broken record, go ahead and invest in a pump, you will be glad you did in the long run
Old Aug 9, 2006 | 09:04 AM
CrawlinWS6's Avatar
Import Patrol
If you are running a wet kit, get the pump for added insurance (as mentioned above). With a wet kit, if sprays the fuel and n20 at the same time. And pulls fuel from the noid. But with a dry kit it uses your current fuel system to get the fuel that is needed. So What I would say is, if you go dry DEF get the pump first. If you go wet get the pump but it is not as pressing.
