newbe ?
Old Aug 9, 2006 | 07:31 PM
Bad N Black's Avatar
Default newbe ?
Can I put a tee on the feed line going to n2o solinoid & run a line to a purge solinoid. install another tee on the purge solinoid run a line inside the car for a pressure guage? Will n2o still work good after all of that? Would Y connectors work better?
Old Aug 9, 2006 | 07:40 PM
00Vette's Avatar
Yes you can! And the T conectors shouldn't be an issue as long as you keep the nitrous moving forward and add the accessory to the T. That way the nitrous flow to the motor won't have to make a 90 degree bend.
I would try to keep the purge noid as close to the nitrous noid as posible though. JMO!!!
Old Aug 9, 2006 | 07:54 PM
THANKS
