fuel test port
Old Aug 11, 2006 | 10:30 AM
edlt1's Avatar
Default fuel test port
what do I need to get my fuel from the fuel rail test port?
I have an lt1
Old Aug 11, 2006 | 10:31 AM
daniel6718's Avatar
a line...remove the schrader valve...
Old Aug 11, 2006 | 10:41 AM
edlt1's Avatar
how do I remove the valve and how do I hook up the line?
edlt1's Avatar
would this be the best way. or should I just use a t-fitting in the feed line
Old Aug 11, 2006 | 05:45 PM
daniel6718's Avatar
no use the schrader valve...it will (line) screw on to it....and u need a tool to remove the schrader valve from a tire is the same...use it to unscrew the valve...
Old Aug 11, 2006 | 11:26 PM
edlt1's Avatar
good stuff thanks man
so just use a 4an
