Trick Window Switch owners please come inside??? Need help programming it!!!
I chose "01=coil packs that fire in pairs (waste spark systems) and the tach wire is connected to the coil"
And what does your window switch display when its in run mode?
I am using a mechanical WOT switch which is mounted under my gas pedal. I do not have the Blue wire connected to anything. So in step 7 of the programming mode I selected "03=turnes this feature off if you are not connectign the blue wire". However the window switch displays "100" when the car is in run mode. In the instructions, 1 which is display A (the first LED) represents the TPAS is on (A=throttle postition activation switch status [o= off/1- onn] ) So what does your guys read? And in your opinion do you think this is correct?
The thing is, my window switch is set to come on at 3000rpms and turn off at 6400rpms. But it don't come on till 5000rpms.
I'm really in need of help. I have a car club race this coming Friday and need to get this fixed before then.
Thanks for the help!
Hope this helps. And you can use the blue wire also on the WOT switch as stated in step 7 for switched ground or hot
