Fpss
Old Aug 15, 2006 | 08:39 AM
Michael Ozorowsky's Avatar
Default Fpss
Hey couple questions:
1) If using nitrous, and the nitrous runs out does it hurt anything or you just go slower?
2) Does a FPSS guarantee you won't hurt anything if your fuel pump isn't pumping enough or fails while racing?
Old Aug 15, 2006 | 08:59 AM
Matt@HSW's Avatar
It shouldn't, but there is always the possibility of a backfire as you'll be running very rich. Most of the time you wouldn't let you bottle go completely empty, instead you would be topping it off every now and again. A FPSS will help you if your pump fails, but like anything mechanical there is no guaranteeing that no damage will be done. If you’re thinking about spraying on top of a cam maybe play it safe and upgrade the fuel pump too.
Matt
Old Aug 16, 2006 | 12:05 AM
what inline pump would I go with? and are they hard to install?
Old Aug 16, 2006 | 12:26 AM
LoWeLL216's Avatar
I'd replace your in-tank pump rather than go with an inline. The Racetronix pump is an easy install and the harness makes it plug-n-play.
