when using the button????
Old Aug 19, 2006 | 11:46 PM
SC_Camaro's Avatar
Default when using the button????
is it ok to let off of the button and the gas at the same time or should i let off of the button first? it seems as i should let off of the button first but then i think of wot switches . reason i ask is because i naturally let off of both at the same time and i have been doing so. causing any problem with completely letting off both together or no?
Old Aug 20, 2006 | 12:43 AM
blind527's Avatar
I have an RPM activated window switch and TPS sensor in 1 window switch...After I'm done spraying, I shut off the nitrous right away, and just drive normally.
Old Aug 20, 2006 | 03:25 AM
SC_Camaro's Avatar
i close the bottle if thats what you mean but i'm talking about the actual red button i'm spraying with. should i let off of it prior to letting off of the gas?
Old Aug 20, 2006 | 08:26 AM
blind527's Avatar
Yeah, that's what I'm talking about. I don't think it matters, because if you have a WOT device, and you hold the button, and you're not going WOT, it stops spraying, even if you're in the RPM range for the nitrous to kick in.
Old Aug 20, 2006 | 08:23 PM
next's Avatar
The guy is saying he does not have a WOT and only runs off a button to activate (not arm) the system. Yes it is fine to let off both at the same time and you will not hurt anything.
Old Aug 21, 2006 | 02:32 AM
SC_Camaro's Avatar
ok thank you. sorry if i was confusing anyone
Old Aug 21, 2006 | 10:41 AM
blind527's Avatar
Yes, I know. I was telling him what I do.
