View Poll Results: Nitrous Activation: Would you spray below 3,000 RPM?
Hell yeah, no question I would!
105
19.13%
Yes, but you're playing with fire and she may blow!
55
10.02%
Maybe, but it depends on the system and safety additions.
123
22.40%
No way, you're asking for broken stuff!
266
48.45%
Voters: 549. You may not vote on this poll
Old Mar 16, 2007 | 06:36 PM
  #61
billybadd's Avatar
Im fixing to spray right out of the hole tonite. Only a 75 wet shot to get my 60ft. down due to some very sticky et streets. The car is really bogging with my converter. (SY3500). Let yall know how it goes.
Old Mar 18, 2007 | 05:26 PM
  #62
BLNLS1/RX7's Avatar
I begin my spray at 2500rpm at 15% and progress up at .9sec at 10% for each additional shot for an end result of 792RWHP and 835TORQUE.This is on my 1999 camaro with a forged 382cu.in. motor.
Old Mar 18, 2007 | 06:08 PM
  #63
midlands's Avatar
Default :-)
Ive sprayed loads below 3000 rpm - nothing bad has ever happened
Old Mar 18, 2007 | 08:41 PM
  #64
sobaka79's Avatar
jinx.......
Old Mar 22, 2007 | 08:29 AM
  #65
brad8266's Avatar
I always sprayed a 150 shot at 2800 RPM's, never had an issue with it.
Old Mar 22, 2007 | 09:17 AM
  #66
ATVracr's Avatar
Spray my 1st stage at 1200 rpms .... Dry shot.
Old Apr 6, 2007 | 07:44 PM
  #67
Taubr Unit's Avatar
on my buddys car with a a4, 4.10's we just foot brake it. no window switch just a WOT switch. So its on right from the dig. Holy hell of a 60ft ill telly ou that much!
Old Apr 9, 2007 | 04:58 PM
  #68
allblacksrt4's Avatar
i hit it right around 1800- 2000 as long as i hook. no window or wot switch
Old Apr 16, 2007 | 10:24 AM
  #69
RedAlertSS's Avatar
Ok guys, I have a problem.. I have a Stock 2002 Camaro SS M6 with 40,000 miles on the motor, My only upgrade is the SLP exhaust.. I have a DRY 100 shot kit of NX sitting next to me and I know nothing about It, Install is no problem, but how do I use it Safely in my car.. I dont care about killing my self.. As long as I dont hurt my motor, What RPM's should I spray at and can I spray from 1st through 3rd Some one please give me a crash course on Nitrous so I dont **** up my 35th ann' If you could, please email the answer to RedAlertSS@aol.com
Old May 10, 2007 | 10:35 PM
  #70
dnkynrbk's Avatar
mine is set at 3200 and 6400 but my shift points are at 6600 and rev. limiter at 6800 3500 stall. window switch and wot switch wet F2 kit
Old May 19, 2007 | 07:25 PM
  #71
jakesz28's Avatar
I was spraying 150 shotout of the hole with a wide open switch. I did this on a 2500 stall and now on my 3600. I just installed a mallory 685 today and set it for between 3000-6300 but I'm considering 2500-6300.
Old May 24, 2007 | 06:01 PM
  #72
John Junkins's Avatar
I'm not going to if I can get the Damn thing hooked up.
John Junkins
Old May 25, 2007 | 10:13 AM
  #73
I_Need_Land's Avatar
i sprayed out of the hole.... i cant hook up for ****. cut a 2.8 60ft, and half a second slower et, with a 12 mph increase.
100 shot.
Old May 26, 2007 | 04:33 PM
  #74
jakesz28's Avatar
100 shot.
You need a good set of tires!!
Old May 26, 2007 | 06:26 PM
  #75
no joke. you seen the video?
look how the camera moves forward then doubles back to see me sitting at the line ahah
http://s38.photobucket.com/albums/e1...gsmokeshow.flv
Old May 27, 2007 | 12:42 PM
  #76
vipershark11's Avatar
wow you got some traction issues with that thing. i sprayed a 125 out of the hole and got a 1.9 60ft on street tires and left off idle. with an LO3 i should add.
Old May 28, 2007 | 03:03 AM
  #77
oh hi, im that guy you talk to on aim alot.
allstock92
Old May 28, 2007 | 02:09 PM
  #78
o ok gotcha.
Old Aug 14, 2007 | 02:17 PM
  #79
skeels's Avatar
Ive sprayed a 75 wet out of the hole the past 2 times ive been to the track. M6, no window switch, just WOT switch . So far so good but time to install the window switch (thinking 3k and 6k)
Old Aug 16, 2007 | 05:35 PM
  #80
0utLawTransAm's Avatar
dont ever sprat that low
