Install Problems
Robert
Next check and see if the fuel pressure safety switch needs to be adjusted. You can just bypass it while testing to see if the system fires..
Check your grounds to the solenoids..
As for the solenoid pulsing did that just happen once?
Dave
Robert
We do not mind at all.
The cool thing is there is always 3 to 4 people that are in the tech offices to answer the phone when someone calls. So when they are in a pinch they can get the help they need when they need it.
Dave
Dave
Robert
Robert
IMHO (as in my case being 50 shot limited with injectors...) The Ultimate dry kit would include the NX Lightning Noids w/ a purge, a Beer Panel, a heater, and a Set of #37 injectors, and a window switch
I have pics of my 99 and were we tapped into to get RPM and TPS signals for the "Trick" Window switch. They are in the wiring sticky.
Shhhhhhh....
Active ingredients are still top secret, but yes some NX goodies amongst others may or may not be included.
Hmmmmm... More like the Ultimate: Ultimate PRO Dry.
