Purge line
Old Aug 24, 2006 | 11:41 PM
mx721suzuki's Avatar
Default Purge line
Currently Im running a 5177 NOS kit (thats N.O.S not NOSSSSSS ) I picked up a purge kit. The noids are mounted by my lid and I know the purge noid should be near it. Id like to run my purge line up to my windshield. Anyone else running this setup? What did you use for line since the kit I got only has about 1 foot of steel line. Thanks!
Old Aug 25, 2006 | 05:03 AM
Kiwi's Avatar
I got this lines in a hardware store and came up with this idea, I hope it helps
Here is another idea for only one side
Old Aug 25, 2006 | 05:04 AM
JustAnIlluzion's Avatar
autoparts store , u can use trans or brake line
Old Aug 25, 2006 | 10:27 AM
Shodown's Avatar
I just used 1/8 copper tubing. Easy to bend by hand and reeeeaaalllly cheap. I got it at O'Reilly's.
Old Aug 25, 2006 | 11:32 AM
nostyta's Avatar
That's what I used.
Old Aug 25, 2006 | 01:01 PM
Bharnz's Avatar
You really need a lid.
Old Aug 25, 2006 | 02:46 PM
trigger1's Avatar
You can see mine right in the center of the cowl area..
Old Aug 25, 2006 | 03:02 PM
Brian2006's Avatar
Brake line is always a good idea but I went to auto parts store and bought 1/8" poly tubing and zip tied it to brake lines and cruise control lines.
If you look really close you can see it coming out of the windshield dam
Old Aug 26, 2006 | 07:42 AM
stevethepirate's Avatar
i used 1/8 copper line tubing also. very easy to work with.
Old Aug 26, 2006 | 08:22 AM
ZexZo6's Avatar
Yea, I went with the dyno tune purge to connections adapted to the zex noid and ran plastic lines. I drilled holes in each corner of the cowl and ran the lines up from the bottom. It looks great. I think the plastic lines are the way to go. I ran 2.5 feet to each side. The lines are flexible which is the good thing about it.
