Quick question...
Old Aug 27, 2006 | 11:43 AM
99ccz28's Avatar
Default Quick question...
Do you advance timing when you run nitrous? Just wondering thanks
Old Aug 27, 2006 | 11:48 AM
wyndzer's Avatar
Yeah advance it about 4 degrees for every 50hp of N2O you plan on spraying.
Just Kidding -- unless you want to burn a piston or something.
You should take out about 2 degrees for every 50 hp of N2O.
Old Aug 27, 2006 | 01:19 PM
sprydncamd ta's Avatar
2 degrees is safe i like the timing tuner because you can run full timing all motor and retard it when the nitrous is activated
Old Aug 27, 2006 | 02:35 PM
99ccz28's Avatar
alright thanks guys thats all i wanted to know...im not actually running nitrous just need to know the answer..thanks
