Is this a TPS switch ?
Old Aug 29, 2006 | 07:00 AM
vette.se's Avatar
Question Is this a TPS switch ?
I got this with my Corvette C5 MAF-plate NX kit, no documentation were included ..... so what is it ?
I think I found how to connect the wires:
Red +12V
Black Ground
White RPM or TPS signal ???
Pink Activate, do this output supply a ground when activated ?
It got one small push button, a red LED and a green LED - how do I set the activation RPM or Voltage ?
Thanks
Old Aug 29, 2006 | 08:20 AM
hangslo's Avatar
If you got a manual with it, look in the back and it will describe the setup procedure. The "button" on the TPS switch is not a button at all, but an adjusting potentiometer to set the "on" voltage for the system. Basically, you open the throttle all the way and turn it till the light goes out, then turn it back up and sneak up on it till the LED comes back on.
Your white wire is connected to the TPS to read the voltage.
I beleive you can also go onto the NX website and read up on it and print out the directions.
Old Aug 29, 2006 | 08:32 AM
turbo86's Avatar
I have this exact TPS switch (AutoLearn), very nice. Go to the below link for exact setup instructions. You don't have to adjust anything on this one, just follow the correct sequence and push the little button when you are supposed to.
http://www.nitrousexpress.com/Instru..._autolearn.pdf
Old Aug 29, 2006 | 09:34 AM
vette.se's Avatar
Thanks !
