dry vs wet test
The only problem I have with the way the test is being done, albeit a small one is that the nozzles will be different and in different locations. I think it would be nice to do the test on a car with a return style fuel system. Like an LT1 or a 5.0 that would allow the nozzle to be located in the same place and you could even utilize the same nozzle for both tests by blocking off the fuel side of a wet nozzle. By doing this you could eliminate any variance caused by different nozzle designs and locations. This would also allow you some A/F ratio adjustments on the dry kit. I think this would be the most accurate way of testing it but I realize that it may not be possible due the fact you may not have access to a car of that type or a kit of that design. All that being said it should be an interesting test that yields good information for everyone.
AFR
Bottle Pressure
Fuel Pressure
Amount of Nitrous used, just for shitz-n-giggles
I will throw out this, wet will make more torque, which in turn will "hit" harder.
ive got a modified mustang kit, that uses a fuel pressure spiker to spike fuel via a 1:1 AFPR...it works superbly.
NA 282 rwhp 284 rwtq
100 dry 347 rwhp 362 rwtq gain of 65 rwhp
100 wet 405 rwhp 409 rwtq gain of 123 rwhp
on a good note, this is the first time i've ever gotten more than rated with the wet kit.
Thats exactly right. The shape of the curve is the key IMO. They would be the same had the flow and AF been the same.
Too bad about the dry kit nozzle placement. They can be finicky. Seems 1 in 8 is lean like that, or so far off it takes some fanagaling to get it right
For those following along here is a link to guys doing dry hits set-up correctly.
Dry Thread
Also is a pic/dyno of a dry hit with plenty of torque coming off the line on a properly set-up dry, about 300lb ft of torque over stock long blocks n/a torque (jetted at 170rwhp).
Robert
my first dry kit was on my 94 z28. nos 05176 125 dry kit. car went from 13.60 to 12.24. worked great. the wet kits don't feel any different.
Robert
