My Spray dyno numbers
Old Sep 14, 2006 | 04:05 PM
RAMPANT's Avatar
Default My Spray dyno numbers
Dynoed my new Nx setup today.
It is a 90mm Daves plate kit. The full NX package.
With a 150 shot it made 638rwhp and 715rwtq. The AF was between 11.8-12.0 and the bottle at 900psi.
NA was 503rwhp.
Does this sound typical?
The curve was wavey, but the purge was not working right so we figured it was wheel spin or purging as it went or both.
Your thoughts, and thanks in advance.
I will take it out on Saturday to see how it does.
Rampant
Old Sep 14, 2006 | 04:37 PM
jermstyle's Avatar
Not bad… I was seeing 138HP with my 150 shot on stock internals. With my new heads and cam I see 98HP with a 100 shot.
Not sure if this is a difference between the two jets though. I’ll be swapping up to 150’s again soon so we’ll see.
What are the specs on your engine?
Old Sep 14, 2006 | 05:56 PM
00Vette's Avatar
That's what I want to know. 500rwhp on motor is crazy!
I don't know how much my 150shot will add. But I dropped from 12.0 on motor to 11.2 with 150 shot, but I don't have near the n/a power you do. I have 100rwhp less.
Old Sep 14, 2006 | 06:32 PM
RAMPANT's Avatar
It went a best last fall of 11.037@127 on motor. The car is not a drag car by a long shot. It is a M6 more than full weight car (3600+lbs without me) that is set up for autocrossing.
I remove the front swaybar, adjust the Koni shocks, swap tires and I'm ready to race
Hoping for mid 10's and 136+mph.
Rampant
Old Sep 15, 2006 | 09:41 PM
Cliff's Avatar
My car weight is similar to yours and the power is similar. I have an 4l60e and went 9.77 @ 137 with a lot left in the car. Yours should run similar times.
Old Sep 16, 2006 | 05:28 PM
johnnyrocket's Avatar
NA was 503rwhp.
Rampant
Was it wavey like my dyno sheet?
