Timing Question...
Old Sep 18, 2006 | 01:45 AM
Blk97WS6's Avatar
Default Timing Question...
Whats up everyone. had a quick question. i recently bought a used Crane programmer from my friend for REAL cheap(otherwise wouldnt have bought it) to correct my speedo after putting in my gears. i found out that you can advance and retard timing with it. im now thinking of upping my 100 shot to a 125 but want to retard some timing. my question is do you think its ok to do it with the Crane, and how much should i retard. -2 degrees? im already running Tr6 plugs gapped at .036, should i regap them for more nitrous? thanks for the help
Old Sep 18, 2006 | 02:14 PM
Matt@HSW's Avatar
No need to retard the timing on those shot sizes if you are running the stock timing tables. If you did advance it with the Crane programmer just take out what you added before you spray.
Matt
Old Sep 18, 2006 | 03:35 PM
Blk97WS6's Avatar
sounds good. i didnt advance any timing with the crane, and it is still running on stock tables. thanks man
